Use the following procedure to configure the SPBM interface parameters.
  1. In the navigation pane, expand Configuration > Fabric.
  2. Select SPBM.
  3. Select the Interfaces SPBM tab.
  4. Configure the SPBM interface parameters.
  5. Select Apply.
Interfaces SPBM Field Descriptions
Use the data in the following table to use the Interfaces SPBM tab.
Name
Description
Index
Specifies an Index value for the SPBM interface.
SpbmId
Specifies the SPBM ID.
State
Specifies whether the SPBM interface is enabled or disabled.
Type
Configures the SPBM instance interface-type on the IS-IS interface located on the specified port or MLT: ptpt or bcast. Only the point-to-point (ptpt) interface type is supported.
L1Metric
Configures the IS-IS Interface level 1 metric on the specified port or MLT. The default value is 10.
You can also configure the L1 metric as auto so the network route is determined by summing the lowest value metrics. The metrics are inversely proportional to port speed.
Origin
Specifies the source of the SPBM instance configuration, either manually configured through CLI or EDM, or dynamically configured through Auto-sense.
